Polaris horrible in the snow PLEASE HELP IF U CAN
i have 3psi in front and 4psi in the rear. I also have the shocks cranked up all the way in the rear. I also have stendori's front spring spacers in the front. I would get tire chains but the problem is i plow paved drive ways wont they dig up the blacktop if it spins? also i always plow in awd and low.
~Polaris man with issues
~Polaris man with ISSUES
#15
i plow with the stock PXT tires, and mine have over 3000 miles on them!!! I plowed 14" of wet snow back in december with no problems what so ever. Another thing to look at is is stops on the bottom of your plow. A good friend of mine has a Moose Counrty plow and he didnt put the stops on the bottom of his plow and all it did was dig his blade down to the dirt. But being your plowing tar you might not have that problem
#16
#17
~Polaris man with ISSUSES
Last edited by polaris man with issues; 02-13-2010 at 09:15 AM. Reason: FORGOT SOMETHING:)
#18
I don't know, something doesn't sound right. I was able to plow plenty of snow with my 500 HO with the stock 489 tires even with the AWD not working right. The PXT's should be even better... but who knows?
Zilla's should be fine in snow, but if it were me, and I wanted a tire for plowing and work around the farm/ranch/property I would get Bighorns or Bighorn 2.0. Unless, I would be dealing with deep mud.
My son has a 400 AC and it is indeed a tank in the snow, but no more so than my 500 was. However, with the his new Bighorns, his Cat is almost unstoppable.
My new 500 King pushes everything that either of those two pushed, even with the crappy stock tires. With Bighorns, it will be even better. Plus, when I take the plow off, it's a lot more fun to ride.
