2 stroke polaris xplorer crank
Old Feb 20, 2010 | 07:15 PM
zooooom's Avatar
Default 2 stroke polaris xplorer crank
I've traded around and ended up with a pretty good looking polaris xplorer 400 2 stroke. The motor is seized up. The piston and jug is bad, I think the oiler quit working. After I got the jug off, the crank is hard to turn over like the bearings are bad. What does this have to do with the oiler? Is there oil in the bottom just for the crank?If I change the bearings and seals should the rest of the bottom be alright?
Old Feb 20, 2010 | 10:25 PM
Doctorturbo's Avatar
GOT BOOST!
Unlike a 4 stroke, a two stroke does not have an oil sump. It is lubed by the oil in the fuel or in your case an auto oiler.
To replace the big end bearing you need to split the crank halfs. This takes special equipment to do.
Old Feb 21, 2010 | 07:08 AM
zooooom's Avatar
So there is no oil level to check in the bottom end? The oil in the fuel keeps the main bearings cool right? The big end bearing is good just the mains are locked up. So... if I do away with the oiler and mix my own fuel it'll be good from now on.
Old Feb 21, 2010 | 10:17 AM
4getful2's Avatar
you do have counterbalancer ,that is driven by the crankshaft gear,that has it's own oil sump(holds 4 ounces).the counterbalancer has it's own bearings and seals that need looked at too. the dipstick for it ,is at the rear of the engine.
Old Feb 21, 2010 | 10:41 AM
zooooom's Avatar
Cool. I got it apart and see the water pump bearing and the countershaft gears have their own oil. The main bearings get their oil from the oil in the fuel right? Or does the oiler split going to the carb and to the mains?
Old Feb 21, 2010 | 11:48 AM
hummer3d's Avatar
Hey i too am trying to rebuild a 400 2 stroke . What Wieght and kind of oill goes in the counterbalance ? I know i saw it in another post but disnt save the info. Thanks
Old Feb 21, 2010 | 05:00 PM
75 cc's of 30 wt OR 10-30 wt oil in counter balancer,check level with dipstick. OPT
Old Feb 21, 2010 | 06:41 PM
hummer3d's Avatar
Thanks Old Polaris TecH.
kelleycully
Sep 15, 2016 02:57 AM
clsharky
Jul 13, 2015 02:07 PM
cornermike
Jul 8, 2015 11:44 PM
Shifts
Jul 3, 2015 07:59 AM
