trickle charger question
Old Feb 21, 2010 | 08:42 PM
polaris 800 plumber's Avatar
Default trickle charger question
Is it bad to leave my trickle charger on my polaris 800 all the time in garage. Or do I need to charge a couple of days before I ride it again..
Old Feb 21, 2010 | 08:48 PM
Outback31's Avatar
Has ridden Rockhouse and Bearwallow trails.
Ive been using mine for 2 years and still have
original battery in my 07 800, it was built in august of 06.
Old Feb 21, 2010 | 09:14 PM
Big-O's Avatar
If it is just a trickle charger and not a battery tender, I would not leave it hooked up all the time. A tender will monitor the battery and only charge it when it needs to be charged, but a trickle charger will charge it at a low amp continuously which could lead to overcharging after time. If you do get a tender it will come with a plug that you can hook up to the battery and leave on the ATV so all you have to do is just plug it in when you park it. Just my opinion, hope this helps.
Old Feb 22, 2010 | 05:12 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
a trickle charger is designed to put a slow charge into the battery where a tender is mae to maintain it when it senses a low charge. make sure the trickle charger if you leave it on has an auto shut off so it won't over chagre the battery and do damage. oh and welcome to the forum.
Old Feb 22, 2010 | 09:36 AM
MECHANIKE's Avatar
welcome,harbor freight sells battery maintainers for $10 or so i've got alot of them..............
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
