2006 Polaris Sportsman X2 Front Wheels not spinng in AWD
I bought a diff off eBay for 369.00 when I opened it up it still had the factory gease on the gears. Don't for get to check for ranger diffs with the same part numbers that's now I found mine.
The newer AWD system with the single front roller cage are not tough like the old twin hub system when it comes to abuse, the single plastic roller cage can explode even with clean fliud and riding with common sence,let alone no fliud and mud in it.
Just another one of polaris improvements for the worst I always thought.
It's pretty much a garden tractor diff in an ATV.I feel bad for you YZHaulR... I've been through it with a crappy front diff. Might as well bite the bitter apple and get a new one.
#15
You can check for power to the front diff,but usually when this happens it's either a cracked roll cage problem,armature plate or both.Updated aluminum roll cages are every where now and about as cheap as the oem plastic ones.Items #10 and 26 on the parts break down. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
http://www.ebay.com/itm/Sportsman-400-500-600-Hardened-Aluminum-Sprague-Cage-Roller-Carrier-ARC-P-022-/191090198991?pt=Motors_ATV_Parts_Accessories&hash=item2c7ddd09cf&vxp=mtr Several videos on youtube about this also.
UPLou
Jun 7, 2015 09:42 AM
May 27, 2015 11:15 AM
