valve adjustment
Old Mar 10, 2010 | 11:41 PM
Polaris500Sportsman's Avatar
anybody know what relay that ramman is talking bout?
Old Mar 11, 2010 | 07:08 AM
Kerbbirds's Avatar
probably the fuel pump relay, under the front hood, I would bet its the fuel pump though, next time it quits turn the key on and off and see if you can here the pump cycle in the gas tank.
Old Mar 11, 2010 | 08:42 AM
Yup the pump cycles after it quits but it sounds really weak
Old Mar 11, 2010 | 08:49 AM
TLC's Avatar
TLC
Did your ATV have the ECM recall done. Polaris Industries Expands Recall of ATVs Due to Fire Hazard
Old Mar 11, 2010 | 05:38 PM
  #15
yeah they have changed that a while back, they also tryed changin the stator as well and it still keeps doin it, but i was thinkin, every time i do an oil change i didnt realize the crank had a drain plug and have just been draining the reservoir, and then putting oil into it, would that cause something to make it stop running after it gets warmed up and has been workin?
Old Mar 11, 2010 | 05:51 PM
  #16
TLC's Avatar
TLC
No I have 3000 miles and just drain the oil tank only also. I never did the crank drain and clean the screen thing. I would cause more damage if I did not repime it right was my thinking. LOL
I do pull start the ATV a few times once the oil tank is drained ,it squirts out a extra cup of oil out that way.
Old Mar 11, 2010 | 06:21 PM
  #17
ok just thought i would check, hahahaha, just talked to my dealer and told him what it was doing, the ECU isn't on the recall list, he said to try cleaning the gas line vent tube, if it gets warm the fuel take would vapor lock and not let the fumes out
Old Mar 11, 2010 | 06:45 PM
  #18
my dealer also mentioned that the fuel tank vent tube could be plugged or pinched off, and when the machine gets warm it would vapor lock the tank and not let the fumes out and have to wait for everything to cool down
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
