valve adjustment
Old Mar 9, 2010 | 01:31 PM
Polaris500Sportsman's Avatar
Default valve adjustment
I wanna get the valves on my 500efi done they have never been done before. Would getting the valves adjusted solve another problem I have. When it gets warmed up and after some slow speed riding it seems to sputter and shut off and then you have to wait for a long time before it will start again0what would be causing this? Hoping the valve adjustment solves it
Old Mar 9, 2010 | 04:28 PM
4getful2's Avatar
when it dies and comes to a no start. check to see if it is getting a spark or getting fuel. valve adjustment unlikely
Old Mar 9, 2010 | 05:14 PM
its almost like its not getting fuel, it will turn over, but it won't fire at all till after you let it sit for a while
Old Mar 9, 2010 | 05:33 PM
Jocko's Avatar
might want to check you cam lobes for wear.
Old Mar 9, 2010 | 05:35 PM
would it have to be taken to a dealer for cam lobes to be looked at?
Old Mar 9, 2010 | 05:37 PM
Jocko's Avatar
Your service manual will explain how you can check them, or you will have to take it to a dealer.
Old Mar 9, 2010 | 05:41 PM
ramman67's Avatar
Default 500
when it dies check fuel pressure and or spark there is a relay that can go bad and cause this to happen.had a fellow bring in 5oo efi about 2 months ago with same problem.once machine got hot relay quit and it lost fuel pump and spark but would crank fine.
Old Mar 9, 2010 | 06:39 PM
where is the relay located ramman?
Old Mar 9, 2010 | 07:28 PM
700 sportsman's Avatar
What year is you 500?
Old Mar 9, 2010 | 11:19 PM
Its a 2006
