CV Joint Spring Clip???
Old Mar 14, 2010 | 08:55 PM
MECHANIKE's Avatar
i have 1 spring clip the exact size of a quarter...........................
Old Mar 15, 2010 | 12:18 PM
pwssr's Avatar
Originally Posted by stendori
ok i just checked(i should have in the first place,sorry) and here is the both clips for the rear cv joint. 1350042Ring, Spring ,7710505Ring, Retaining
the first number is the clip that holds the cv into the rear housing, and the second number is the clip that holds the cv joint together on the inside on the shaft.
Thanks a lot, Sten - got a few on order.
After looking at a fiche that DOES have it (different model), it looks like they just forgot to put it in the fiche for the '01 500 HO!
Old Mar 15, 2010 | 12:20 PM
pwssr's Avatar
Hey, thanks for looking! I don't know the size - not apart yet!
Looks like Sten solved the part number issue too!
Old Mar 23, 2010 | 01:38 PM
pwssr's Avatar
Sten - I received the clips - the part number is good!
Thanks again!
Paul
Old Mar 23, 2010 | 07:11 PM
  #15
stendori's Avatar
Super Quad Patrol
I'm watching you!
Thanks again!
Paul
glad i could help and it worked.
Old Mar 24, 2010 | 07:58 PM
  #16
09 popo HO's Avatar
Are these part numbers good for all Polaris axles?
Old Mar 25, 2010 | 04:53 AM
  #17
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would guess yes they would be, but i could check on the year and bike if i knew what it was tonight when i get home.
shimanok2
Jan 29, 2016 07:37 PM
black_thunder
Sep 22, 2015 07:59 PM
89Lt250r
Sep 7, 2015 07:53 PM
Sep 2, 2015 11:15 PM
