HELP electrical problems sportsman 400
Old Mar 17, 2010 | 12:08 AM
mottomotorsports's Avatar
Default HELP electrical problems sportsman 400
hey i have a 03 sportsman 400 that doesnt charge, the batt light blinks, no charging at all with voltmeter attached, i just purchased this found it had been sitting for some time it suposed to work fine befor it sat, now it doest charge, and the cooling fan doesnt kick on, anyone have any ideas? im a mechanic but never worked on 4wheelers these are a little differnt haha leme knoe thanks
Old Mar 17, 2010 | 01:01 AM
bcdudley's Avatar
Are you saying it is running and not charging? If it has been sitting for a while, the battery is almost certainly dead. This should probably be the first thing you check.
Old Mar 17, 2010 | 04:40 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if the battery is good and charged, check the recifier(regulator) to see if it has a bad connection or corroded. if it's not a bad recifier then most likely a bad stator or maybe rusted connections by the pick up coil.
Old Mar 17, 2010 | 06:48 PM
hahaha i said i was a mechanic i got the battery covered i jsut dont know much bout the stator and pickup coil and how u test these things i have a service manual for it and it says to check the battery coils, charge coils, stater coils. eciter coils. is this all the stator? i know different wires, and where is this pickup coil/?? the manual states the volatge regulator is not testable so if anyone can help me with that as well. im leanin towards the stator, prolly built up rust is this removable and cleanable cuase if im right this is like close to 400 bucks.....thanks for the help!
Old Mar 17, 2010 | 07:14 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
There is a 3 ways to test your stator. It should describe it in the service manual. I just went through all of this with my 07 sp 500. Test-1 resistance value of each stator leg. Test-2 resistance value of stator leg to ground. Test-3 measure AC. voltage output of each stator leg at charging RPM. If these tests don't come up to snuff then I would suspect the stator is weak or toast. Have you pulled the recoil housing to see if there has been any water ingestion? Water+electrical components= not good And yes the stators are a little pricey.
Old Mar 17, 2010 | 10:18 PM
bcdudley's Avatar
I just bought a new stator 2 weeks ago from RickyStator.com. It was only $150. I have not really had it long enough to say if it is good or bad yet, only that it is working. It certainly beats the pants off of $400 for a new one from Polaris. Even if you have to buy a replacement in 3 or 4 years, you still come out ahead by $100.
Old Mar 18, 2010 | 10:43 PM
i checked all the resistances and they dont look well what two wores would i check for a/c volatge on, i imagine with the battery unhooked start it and check for it making volatage, maybe between the yellow and yellor/red wire?
Old Mar 18, 2010 | 10:44 PM
and is it commen fo the stators to take a poop?
Old Mar 18, 2010 | 10:55 PM
bcdudley's Avatar
Look in front of the radiator. There is a small box with 4 or 5 wires going to it, don't remember how many. Unplug the yellow and the yellow/red. Test the resistance between them on the wires running back towards the engine with a digital ohm meter. If it shows an open circuit, either the stator or the wires going to it are bad. There are also several other test you can perform.
See this thread for a little more info on testing, or if you would like, you can pm me and I can give you a copy of the service manual.
http://forums.atvconnection.com/pola...k-battery.html
Unfortunately, yes, the stators do seem to go out quite often judging by all the questions about them on these forums. Water and electricity do not mix well together.
Old Mar 19, 2010 | 09:22 AM
To do a vac test (AC current off your stator) Leave your battery hooked up. Pull the plug coming from your stator and there should be three yellow wires. Those are your three legs. With the engine running set your meter to AC./VAC. and and take readings from your legs. It does'nt matter witch probe is where, just measure the voltage as follows. Leg 1 to leg 2, 1-3, 2-3. you should come up with the same voltage each time +- 15%. Refer to your service manual for proper voltage output on your model.
ripperray
Oct 10, 2023 02:42 AM
skittero
35
Mar 1, 2019 12:39 AM
Raccar1
Jun 18, 2015 02:17 AM
DOAinNY
Jun 11, 2015 10:34 PM
