cv boot for 97 sportsman 500
Old Mar 21, 2010 | 04:51 PM
ardakota's Avatar
Default cv boot for 97 sportsman 500
I cant find the rear inner cv boot on the parts fiche does anyone know if the front is the same as the rear or are they differant.
Old Mar 21, 2010 | 06:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you mean the univeral joint? the out side toward the wheel is thre cv joint part of it onthe earlier bikes. looking at the parts break down it only list one under cv joint so maybe all 4 sides take the same.
http://parts.polarisind.com/Assemblies.asp
Old Mar 21, 2010 | 06:29 PM
ardakota's Avatar
the back one is by the rear end and is a u joint by the tire if im thinking right
Old Mar 22, 2010 | 05:19 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the cv joint is out by the tire and the univeral is inside near the transmission. the outside had the slpined shaft which goes thru the wheel hub and mounted w/ the big nut to hold it on.
Old Mar 22, 2010 | 11:31 AM
TLC's Avatar
TLC
The 97 only had u joints, there was no CVs on the 97 Sportsman. I think it was 98 that CVs were first used.
Old Mar 22, 2010 | 05:01 PM
ardakota's Avatar
I was mistaken so im gonna need the slip joint boot. My memory isnt too good any more it seems thanks
Old Mar 22, 2010 | 06:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the break down i saw was on a 97 w/ the outter side being a cv joint.
http://www.ronniesmailorder.com/fich...1997&fveh=5443
Old Mar 22, 2010 | 09:22 PM
TLC's Avatar
TLC
Thats odd we own a gneen 97 SP500. we have to grease a ujoint on each end of the shaft.
http://www.cyclepartswarehouse.com/f...1997&fveh=5443
Old Mar 23, 2010 | 04:58 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i know huh. maybe the parts brake down is wrong, and sense you have one i would tend to think you know as you can see it lol.
Old Mar 24, 2010 | 09:12 AM
TLC's Avatar
TLC
Maybe they made a improved replacement axle, with aleast one cv on the outside now.
