Battery dead NO START with pull cord??
Old Mar 26, 2010 | 10:22 AM
surfcaster's Avatar
Thanks to all you guys, you have answered my question and very much appreciated.
surfcaster + an extra battery
Old Mar 26, 2010 | 11:17 AM
Big600twin's Avatar
why don't you disconnect the battery and see if it will pull start at home so you know what would happen.
Old Mar 26, 2010 | 11:21 AM
Speeddrive1's Avatar
Get one of those rechargable jumpstart things with the built in air compressor and flashlight built in so if your battery does go dead just hook it up and giver a start. Also the little air compressor could pump up the tire if you get a flat.
Old Mar 27, 2010 | 12:08 AM
Kerbbirds's Avatar
if you have some buddies that go with you, take a set of jumper cables thats what i have to do beings that my 700 has no pull start
Old Mar 27, 2010 | 10:36 AM
  #15
TLC's Avatar
TLC
Originally Posted by Kerbbirds
If the battery is dead on an efi machine it will not start, no computer or fuel pump without battery.
Pretty pointless to have a back up pull starter then. On my 2001 I rode it for a month with a dead battery and just pull started it every time before finally getting a new battery.
Old Mar 28, 2010 | 09:47 AM
  #16
ramman67's Avatar
Default 500
It will not start with a dead battery even with the recoil.has to have battery voltage present approx 5 volts to run efi and dc ignition system.
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
vipers
May 31, 2015 09:12 AM
1000gade
May 27, 2015 12:37 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
