question about xp ball joints
Old Mar 31, 2010 | 08:16 PM
nc porider's Avatar
Default question about xp ball joints
on the recalled quads were the ball joints bad as in had play in the ball joint itself or did the steering knuckle give way where the ball joint connects ? the reason i ask while riding today checked my wheels and the ball joints on the front left had play in the ball joint itself and when i called the dealer he told me he thought it was the steering knuckle that was the problem the bike has only 275 miles and he wants to hit me for 325.00 for 2 ball joints because the 6 month warranty went out 5 days ago.CRAP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 31, 2010 | 08:27 PM
ts01fan's Avatar
The xp's recalled are having problems on the ball joint where the pinch bolts connect the tie rod to the wheel hub and $325 for 2 ball joints is OUTRAGEOUS.I sure hope that price included several hours of "shop" labor.
Old Mar 31, 2010 | 09:06 PM
nc porider's Avatar
Default ball joints
the pinch bolt area seems to be ok so i must have just bad ball joints and yes the 325 included 3.5 hrs labor but i think i can handle changing the ball joints myself. I just wanted to make sure because i don't need any help in the crash department.
Old Mar 31, 2010 | 09:20 PM
ts01fan's Avatar
Definitely should not take a professional 3.5 hours to change a set of ball joints. I here what you sayin about the crash department. Probably something you can tackle yourself even if you dont have a great deal of mechanical skills and save yourself a lot of money.
Old Mar 31, 2010 | 09:56 PM
Mongrol's Avatar
"Official Site Skeptic"
There is apparently a general recall & N/C for all XP;s. Mine cost me nothing to repair.
Old Mar 31, 2010 | 10:13 PM
Mongrol's Avatar
Here's the recall info.
http://forums.atvconnection.com/pola...ecalls-xp.html
Old Apr 1, 2010 | 06:11 AM
Miaugi's Avatar
Don't give up on getting it done under warranty. I had a similar problem with expired warranty and I was told US dealers (I'm in Canada) will usually give a 10 day "grace" period. If they say no call Polaris directly and speak to them, be sure to mention how much you paid for the bike, that the XP is their premium machine and that you know there is a problem with the ball joints. I had my repairs done under warranty after kicking up a fuss. Good luck!
Old Apr 1, 2010 | 09:50 AM
TLC's Avatar
TLC
I,m sure there are aftermarket ones from a auto supply store that would work. I doubt Polaris uses custom built tie rods or ball joints.
On the Sportsmans people just bought parts like that from NAPA.
Old Apr 1, 2010 | 01:37 PM
Mongrol's Avatar
Keep in mind that this is a recall and doesn't fall into regular warranty.
Old Apr 1, 2010 | 05:22 PM
nc porider's Avatar
Default ball joints
at first he ran the vin said not under recall, but he called today and said all is good taking the bike in next thursday to be fixed on polaris tab so that worked out
