Clutch removal
Old Apr 9, 2010 | 04:37 PM
tonythom's Avatar
Default Clutch removal
I have been trying to get the clutch assembly off my 03 trailboss. I have a 3" bolt that I have threaded into it. Also put a 2-3' 3/8 drive extension and a socket behind it. When I crank down on the bolt nothing happens. I had to remove bolt and put a larger socket to get more depth. I also pulled out sockets and filled it with grease hoping the hydraulic pressure would help. I used a 4' extension bar, socket goes in but clutch does not come off. Ant ideas. thanks tony
Old Apr 9, 2010 | 05:37 PM
ftwflh's Avatar
Best to find a puller before you mess up something
Old Apr 9, 2010 | 05:40 PM
If you have access to an air compressor and a 1/2" impact,IT will come right off!! I've only had a couple over the years that I've had to heat up under pressure or tap the head of the tool to remove.
Old Apr 10, 2010 | 03:28 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
an impack does the best job for sure. sometimes you have to tap the end on of the puller for a shock effect.
Old Apr 10, 2010 | 07:22 AM
TLC's Avatar
TLC
Watch and learn.
YouTube - Changeing belt POLARIS ATV
ghost civic
Jan 15, 2020 07:43 AM
merryman
Jan 19, 2016 04:29 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
