What is the right size winch for a XP 850?
There only 70lb differemce between the 500 and 850.2010 Polaris Sportsman® 500 H.O. ATVs
Definitely go the 3000lb route, minimum. You have to keep in mind that the pull rating of a 3000lb winch is only actually 3000lbs when there is only one layer of cable on the winch drum. The more layers of cable on the winch drum, the lower the pulling power. Most manufacturers usually have a chart for each of their winches that shows the load pulling loss brought on by the increase in drum diameter from multiple cable layers.
Since most pulls never call for running your winch line out to where there's only one layer of cable on your drum, its best to make sure the winch you buy can pull your quad out at half capacity. I went with KFI's 3000lb winch and haven't had any trouble pulling my 500 out of some deep holes with straight line pulls.
#15
