01 sportsman winch cable
Old Apr 26, 2010 | 08:14 AM
stcspiderman's Avatar
ok thanks I think I will go with that.
Old Apr 26, 2010 | 09:06 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
If you get the synthetic rope, make sure your fairlead rollers are smooth and burr free before installing the new rope. Either buy a new set or do like I did by taking each roller and sanding them down to like new condition. I put the mounting bolts in them tightly and then sinched the bolt down into the chuck of a drill press. Makes sanding effortless and only takes a couple minutes to have them looking brand new again. Or use a standard drill mounted in a bench vise. Very important to do this or you could risk chaffing the rope under pressure.
Old Apr 26, 2010 | 09:14 AM
itsfit's Avatar
master pull sells chaf gaurds which i just bought it will protect it from chafing if you are pulling over rocks or logs
GregM
Mar 6, 2018 06:53 AM
Karas3434
Aug 3, 2015 09:17 AM
Schneider
Jul 24, 2015 05:05 PM
Bratman2
Jul 23, 2015 12:36 PM
cornermike
Jul 8, 2015 11:44 PM
