04 sportsman 400 intermittent spark
Old May 11, 2010 | 05:33 PM
TRX1000's Avatar
Default 04 sportsman 400 intermittent spark
ok well a week or so ago i put my dads polaris into the storage buliding on our property, before putting it in i turned off the gas and let it idle out. well a week later i pull it out turn gas on and let it warm up. then i go to take off and it started to move and died, like it was out of gas, well i found that it would lose spark above idle and below 4000RPM, if you kept it above 4000 it was good. then it would die. i you revved a couple times in neutral then it would evertualy die, if you turned it off then back on it would fire and stay running for a little whil till it shut off agian? i have cleaned the plug and truly verified that is loses spark. what do you guys think? thankyou
Old May 12, 2010 | 06:58 AM
Kerbbirds's Avatar
Is it one of the machines with the ECM recall, sounds like that could be it.
Old May 12, 2010 | 04:30 PM
TRX1000's Avatar
it did have the recall, we already took it in last year to get the recall fixed...does anyone have instructions on how to test the stator and pulse/pick up coil? thankyou
Old May 13, 2010 | 09:28 AM
TLC's Avatar
TLC
Take the recoil cover off ,the pulse coil can get dirty and need a cleaning and re gapping.
Old May 15, 2010 | 09:04 PM
TRX1000's Avatar
alright took the cover off... the pinion on the started drive is a slight bit worn and there are tiny metal particles floating around in there. so the flywheel has to come off, is it a left handed thread and is there anything behind it that i have to worry about. and when i get it back together what should the gap be? thankyou
Old May 15, 2010 | 11:05 PM
TLC's Avatar
TLC
Just make sure the Trigger/Pulse coil's surface is clean and get it gapped close to the flywheel without rubbing.
Old May 16, 2010 | 11:36 AM
TRX1000's Avatar
well i pulled the flywheel and checked the clearences. it was .026" between the pick up and the trigger on the flywheel. well i stumbled upon something else. while looking at the stator and flywheel i can see where the stator seems to be contacting the flywheel. it looks polished. are they suppose to be touching or not?
Attached Thumbnails 04 sportsman 400 intermittent spark-polaris1.jpg   04 sportsman 400 intermittent spark-polaris2.jpg
Old Aug 21, 2010 | 10:19 AM
TRX1000's Avatar
anyone have an idea? i havent messed with this thing in a while but i keep running into it in the shop so it needs to run!! i can get it to idle but once i put a load on the charging system(turn lights on) it shuts off, or if i touch the throttle it will shut off, i have removed the fly wheel and cleaned everything, i was wondering if i could run it with the stator unplugged, the pick-up still plugged in and the battery on a charger? my dad wants to take it to a stealership and i wont allow it!!! I dont have much time till his parental abilities take over!!
Old Aug 22, 2010 | 02:25 PM
TRX1000's Avatar
ANY ideas are welcome!! So does anybody know if i can run it with the stator unplugged and the pick-up still plugged in?
Jmuddin284
Jan 19, 2026 07:16 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
