Rope
Old May 13, 2010 | 04:34 PM
hallj86's Avatar
Default Rope
Do I have to use a fairlead instead of the roller that can with my cable?
Im not really sure what to do when I make the switch
Old May 13, 2010 | 05:49 PM
From what I've read you should change the roller fairlead and put a new one on. The regular cable can put nicks in the older fairlead which would lead to cuts in the rope over time.
Old May 13, 2010 | 07:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i think you do need a differnt roller fairlead for use w/ the syn rope.
Old May 13, 2010 | 08:11 PM
uncle matt's Avatar
I run a synthetic rope and this is what my fairlead looks like. I don't have the flat rope like this.
Old May 14, 2010 | 06:32 AM
james feeney's Avatar
It doesn't really matter what fairlead you use, as long as it is in perfect condition. Chances are if you've used steel on it before now you'll want to change it. If you are using rollers, make sure the bolts are tight.
We used to use alloy hause fairleads but found they weren't tough enough and since moved to stainless. Though I'm sure alloy would be fine for ATV useage. Even a steel hause will be fine as long as it is baby bum smooth.
James
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Alex G.
Sep 19, 2015 06:34 PM
Fubar008
Sep 1, 2015 07:14 PM
toonces
Jul 31, 2015 09:27 AM
