engine hot no awd
Old May 15, 2010 | 11:14 PM
fishycliff's Avatar
Default engine hot no awd
ridin and the low beams blew because of water both sides shortly after warning lights for engine heat came on and the battery light also water blowing from overflow at one point . no water in oil this is my 600 sportsman could the lights blowing out cause all that oh the all wheel drive wuoldnt workfan was week to next day okay havent replaced bulbs yet could the bulbs have effected the system/electrical what do yahll think
Old May 16, 2010 | 05:44 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would check voltage out put to make sure it's all sudden not way over charging. does the speedometer still work? is the awd light/indercator work saying it's awd?
Old May 16, 2010 | 08:29 AM
TLC's Avatar
TLC
The fan has to spin at its correct speed to prevent over heating. Is the twigs or stuff in the fan restricting it or is the fan noisy and grind which means its blade bearing is wearing out. Should spin easily by just touching it with you finger.
If it needs a fan these guys sell them 70% cheaper then the dealer. SPAL USA
Old May 16, 2010 | 10:52 AM
fishycliff's Avatar
Awd indicater was on battery warning went off that night while riding fan was coming on but slow tach trip work mph doesnt new one on the way hasnt worked since i bought it last year hopeing all these problems were because the lights blew conections got wet no coolant leaks since trip atv is in my garage checked the water everyday hasnt moved
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
