01 trailboss clutch grinding noise
Old May 23, 2010 | 07:55 PM
kevinkading's Avatar
Default 01 trailboss clutch grinding noise
My 2 wheel drive 325 trailboss grinds when going forward with a load on it. When it is up on jacks in forward it is fine. I have taken the driven clutch apart and it is in good shape so i took the transmission apart and it seemed to be in good shape. I am stumped any ideas will be greatly appreciated.
Old May 23, 2010 | 09:38 PM
4getful2's Avatar
if both sprockets have all there teeth and the chain is set proper,you may have a bad chain in transmission
Old May 24, 2010 | 03:22 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. is it's grinding like when you are trying put in gear and gears are messing or is it sipping like a loose chain on a sproket? the clutches wouldn't make it grind.
Old May 24, 2010 | 09:13 PM
the gears are not grinding when it is being shifted. It just grinds when i am riding
Old May 25, 2010 | 04:52 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
was the silent chain in the trans. loose?
Old May 25, 2010 | 08:08 AM
scootergptx's Avatar
Supersock
Hired Gun!
I agree with Stendori, take a look at the silent chain.
Apparently, it's given up it's vow of silence.
Welcome to the forums.
Old May 25, 2010 | 03:14 PM
Ding Nut's Avatar
I had the same problem with my 03 trailboss.....REPLACE THE SILENT CHAIN.
I did and it fixed the issue.
Old Nov 9, 2011 | 01:38 AM
Burton101's Avatar
Did u find out what the problem was? I am having the same issue! And it soundsd like its coming from the primary clutch
Old Apr 27, 2020 | 08:47 AM
Marlene Jacobs's Avatar
Default Polaris 325 trail boss
When put into gear it takes off immediately
and when riding it sounds like the chain is slipping I’ve tightened up the chain but yet I still hear the noise. Please help if you have any advice
Bill Haney
Jan 3, 2016 04:30 PM
hondaguy7983
Dec 16, 2015 01:49 AM
Burton101
13
Nov 10, 2011 02:52 AM
Zbart1
Feb 20, 2006 11:39 AM
Batoutahell
May 21, 2002 10:54 PM
