Location of Winch Solenoid
Old May 27, 2010 | 03:34 PM
Indslpwr04's Avatar
Default Location of Winch Solenoid
I have an 07 Sportsman 800 and have the factory Warn Winch. Where is the Winch Solenoid located. My winch will only go in and i have it so jammed in the fair lead that i cant even free spool it back out.
Old May 27, 2010 | 04:30 PM
CROOKED STEP's Avatar
check under right front wheelwell up high might have to remove front storage thats where it is on wife's 07 500
Old May 27, 2010 | 04:38 PM
EPIChad's Avatar
On my 08 800 Sportsman its on the up high on the frame behind the front right tire.
Old May 27, 2010 | 07:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
no need to take storage box off. just 2 bolts hold the plate to the frame and it will drop down to see the conntacter.
Old May 28, 2010 | 09:55 AM
Indslpwr04's Avatar
Thanks. I found it and did some testing. The Winch works when jumped off of the battery and the switch works fine, checked with test light. Tested the conntactor and got no power going to winch in the out position. Anyone changed it out for a different type? The + and - lead from the battery is molded together in one piece so it may be difficult unless i cut them apart.
Old May 29, 2010 | 09:24 PM
700 sportsman's Avatar
I had a gorrila contactor, and it's connectors didn't work the way the cables were molded together, so I used my dremel tool and cut in it half. But I would say a warn contactor from ebay would be the best route
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
EIF
Apr 20, 2017 07:15 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
Jackg17
Sep 26, 2015 09:30 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
