HOW 2? bypass speedo for 4x4
What is the easiest way to bypass the speedo to get the 4x4 working. I have an 02 500 HO. speedo back light works, neutral light works, rev light works, but the needle does not move. For some reason it seems everything operates off the speedo. Sounds like a great money maker for polaris as speedo is around $300.. Is there a way to bypass this? I have found this topic, but I need specific info and how to information. Thank you in advance
Paul
Paul
welcome to the forum. there are sevral post of this very subject if you do a search. now i'm not 100 sure w/ out reasearching(no time right now) but it should be the brown or brown/white white on the speedo harness i lthink like pin number 16(sorry can't remember for sure) that i belave needs to be grounded and the awd should work. like i said if you search you find the info.
speedbuff
13
Nov 11, 2020 10:16 AM
jrooker6
Apr 23, 2016 07:36 PM
