bearing trouble
Old May 28, 2010 | 07:14 PM
fishycliff's Avatar
Default bearing trouble
05 600 sportsman rear differential do they make a puller small enough to remove it its the one behind the or at the end of the rear shaft spline tryin not to take the whole rear out but check all auto stores cant find one small enough to get in to pull it i need help any tricks to the removel
Old May 29, 2010 | 08:25 PM
4getful2's Avatar
if you are talking about the rear hub assembly,yes you will have to remove the hub to install the bearings. the cv axle needs not to be removed.
Old May 30, 2010 | 07:00 AM
helmethair78's Avatar
I just rebuilt my rear diff. There is no way around it you will have to pull it out.
Old Jun 1, 2010 | 09:43 PM
fishycliff's Avatar
is their a special bearing puller for the bearing at the shaft to the rear differential if i have too pull it are the rear cvs at the differentil hard to put back never been in it
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
jbrewster94
Sep 23, 2015 04:16 PM
