95 Sportsman 400 reverse issues
Old Jun 4, 2010 | 04:39 PM
Big600twin's Avatar
Default 95 Sportsman 400 reverse issues
Idles fine and runs good in forward but when shifting into reverse the machine dies. It will stay running in reverse with the override button pushed but if not when in reverse the machine dies. Anyone have some suggestions???
Old Jun 4, 2010 | 10:58 PM
mwhod's Avatar
i just had that problem with a 500 sportsman, one of the guys on here pointed me to the reverse limiter, that was causing my problem, it was kicking in and causing it to die in reverse, i looked up a fix for it and bypassed the limiter and the bike works fine, now, i like it much better, only requires a little wiring under the hood,
mike
Old Jun 5, 2010 | 04:00 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yep the reverse limiter is messing up by the sounds.
Old Jun 5, 2010 | 08:32 AM
ftwflh's Avatar
Find the black wire coming out of the limiter and unplug it.Problem solved.If you want to replace the reverse limiter I have a used one but unplugging is the way to go.
Old Jun 7, 2010 | 12:10 PM
Big600twin's Avatar
As always thanks for the help. This was for a buddy and he will look into the black wire and let me know....
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Shifts
Jul 3, 2015 07:59 AM
bikedad3
Jul 2, 2015 02:15 AM
Fullblast
May 26, 2015 12:38 AM
