High Voltage
Old Jun 28, 2010 | 12:11 PM
tonythom's Avatar
Default High Voltage
I rebuilt the motor on my trailboss and had to change the bottom end. This meant unhooking the wiring harness that goes up under the hood. Since then I ahve burne dout a couple cdi's. I put a voltmeter on the battery and started it and the voltage goes up to 30 volts when I rev it a little. Any ideas what could be hooked up wrong. I double checked my wiring, Changed my regulator/module box and things are no better. Any ideas. Thanks Tony
Old Jun 28, 2010 | 03:04 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
You may have inadvertently caused damage to your stator during your rebuild. If it is shorting out it could start throwing to much voltage rather than not enough as one would expect to see. It's not very common but can happen.
Old Jun 28, 2010 | 03:16 PM
tonythom's Avatar
Got my voltage right, It was a bad meter and readings. Still if I rev the motor any the cdi wiull smoke and get hot. When I was rechecking voltage I saw smoke and turned off key. Moter would not turn off and I had to choke it to kill it. So voltage is ok but something is burning the cdi. Most of the connections are different enough to not confuse them, spade, bullet, plugs. Could anything else be causing this. Stator was in motor I got and I still have the original. HSould i change it. COuld it be sorting the cdi and not putting off bad voltage? Thanks Tony
Old Jun 28, 2010 | 06:39 PM
If your voltage is right and your not seeing any voltage spikes I'd be tracing wires to see if any have bare spots and grounding against the frame or what-not. Not to mention check all your ground wires for good connections.
Old Jun 28, 2010 | 07:41 PM
The Kid's Avatar
start checking grounds
Old Jun 28, 2010 | 07:57 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
either that or you got some pinched wires or hooked up wrong.
Joe454
Nov 20, 2020 01:19 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Gwolf228
Feb 18, 2017 01:36 AM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
