02 Sportsman 700 where is the voltage regulator
Old 07-09-2010, 08:37 PM
sammydogs64's Avatar
Default 02 Sportsman 700 where is the voltage regulator
My battery is not charging on my sportsman, a voltage test shows 12.8 volts with key on (not running) 12.4 volts idling or reving with lights out. From what I understand its should go up to at least 14volts.
So all it can be from my experience is the regulator/rectifier or Stator. The machine does run even with a completely dead battery so the ignition stator is working. I am not certain if polaris uses seperate coils in the stator for ignition and charging.
Any insight would be appreciated.
Old 07-10-2010, 07:48 AM
Small module in front of radiator,3 yellow, one red and brown leads. Check for any disconnected leads. If all are connected,most likely reg/rectifier. Only have had a couple stator related charging problems over the years. OPT
Old 07-10-2010, 08:37 AM
TLC's Avatar
TLC
TLC is offline
Part #23 in pic below.
skinnyr6
08-25-2023 02:18 AM
Bulgin88
08-01-2015 06:39 PM
DeFox500
07-26-2015 06:32 PM
Schneider
07-24-2015 05:05 PM
200es
07-19-2015 04:50 PM
Quick Reply: 02 Sportsman 700 where is the voltage regulator
