Coolant leak in 1996 400L
Old Aug 6, 2010 | 07:32 AM
Neptugian's Avatar
Default Coolant leak in 1996 400L
I have a great running 400 sportsman with a slow coolant leak near hose insertion into the block. I cannot diagnose this further.
Is this a "big" problem? Common problem??
Any suggestions are appreciated.
BB
Old Aug 6, 2010 | 02:49 PM
Overdrive's Avatar
Is it leaking from the water pump weep hole?
Old Aug 6, 2010 | 02:54 PM
02magnum500's Avatar
Gets his share of deer.
Or the hose barb? I have had it leak from the hose barb, need to tighten up the clamp or add a new one.
Old Aug 6, 2010 | 06:02 PM
4getful2's Avatar
try a few ounces of radiator stop-leak,not the whole bottle ,though as your cooling system only holds about 2 qts.
Old Aug 7, 2010 | 03:22 PM
biggerten's Avatar
ixnay on the op-leakstay. Is that the original hose? Now nearly 15 years old? Hoses deteriorate with age.
Old Aug 8, 2010 | 10:07 PM
Neptugian's Avatar
Thank you all.
I will flip it on its tail and change the hose. It runs way to well for it to be major.
(wishfull thinking!)
BB
exmotocrosser
Sep 13, 2019 06:12 AM
Alex G.
Sep 11, 2017 11:38 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
