Polaris 4x4 97 4 stroke *
Magnum 425
Sits at an idle but went to give gas and bogs out and doesn't want to run won't die but doesn't want to run right and just had a new carb built any thang u can tell me thx *
srry forgot to put that in there but it has new cam new timeing chain and timeing has been set valves have been adjusted carb was rebuilt with all new parts
Some thing else to check: make sure you have the cam detent lever and spring correctly installed or it can do the same thing you are describing,idles but wont take throttle! OPT
i will check the spring and lever again but i let polaris put it all together so hopefully they know what there doin lol im more of a sport quad person
