oil injection
Old Aug 24, 2010 | 06:36 PM
polcat1p's Avatar
Default oil injection
i would like to not use the oil injection. can i just not fill the tank, or should i remove everything? if i remove what ratio do i uses?
99 scrambler 400 4x4
Old Aug 24, 2010 | 10:15 PM
mrtwostroke's Avatar
pull the pump out, drive the pin out that holds the drive gear on. remove gear reinstall pump. ratio 40 to 1
Old Aug 25, 2010 | 08:23 AM
TLC's Avatar
TLC
Is the oil injection not working ok? Oil injection id better then mixing because it calibrates your oil to the rpm of the motor. At idle it may mix oil at 20:1,at mid range it may be 30:1 and at wide open 40:1.
Premix is 40:1 100% of the time , more oil used and more fouling plugs on slow trail riding.
Old Aug 25, 2010 | 02:29 PM
polcat1p's Avatar
im not sure , i just got the bike. its more of i dont trust it. what if it stops working, there goes the top end
Old Aug 25, 2010 | 04:20 PM
EPIChad's Avatar
I have seen some block off plates and kits to do it if wanted. I think HPD (High Performance Designs in Minnesota use to have one) Only time i have seen people do it is for race applications to save weight and hp. For normal trail use I would use the injection.
Old Aug 25, 2010 | 09:29 PM
TLC's Avatar
TLC
I,m sure it trust worthy, I seen alot of Polaris 2 stroke Sleds turn 10,000 miles with the oil injection,I,m sure they have it down packed on there ATVs also.
Old Aug 25, 2010 | 10:54 PM
idle mixture more likely 100:1 getting richer from there to wide open not the other way around. I have yet to foul a plug, plug fouling is more often a result of incorrect air fuel mixture. unless you are running more than 32:1 oil
Old Aug 25, 2010 | 10:56 PM
TLC's Avatar
TLC
Oops your right, leaner at lower RPM I ment. LOL
Cummins Driver
Sep 11, 2019 01:22 PM
dwhipper61
Aug 27, 2015 11:01 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
