Need more power, any advice??
Old Aug 25, 2010 | 12:08 AM
NCPolaris's Avatar
Default Need more power, any advice??
Hey, new to this. Easy question, I have a 03 Polaris Magnum 330. Great machine, clean, runs great, but several times it seems to lack the power to start off from a dead stop to get up out of a creek bed or whatever. Is there anything I can do to add power, or am I better off just going up to a bigger machine? Trying not to break the bank! Thanks for your help!
Old Aug 25, 2010 | 05:08 AM
Kerbbirds's Avatar
clutch kit
Old Aug 25, 2010 | 06:12 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Ditto! Clutched my 325 magnum and it acts like it's got tons more power.
Old Aug 25, 2010 | 06:53 AM
TLC's Avatar
TLC
Use low range for trouble spots like that, its free..
Old Aug 25, 2010 | 08:21 AM
NCPolaris's Avatar
Ok great. Can you give me a ballpark idea of what a clutch kit goes for installed? I've used low gear, not enough. What about a new exhaust or jet kit? Thanks again
Old Aug 25, 2010 | 08:30 AM
TLC's Avatar
TLC
If low range is not enough than it may be a power issue not a clutching issue. The easiest Power gain on the 500 at least is a slip on muffler about $250,more bottom and mid range without jetting if you get the right muffer. Should hold true for the 330.
Old Aug 25, 2010 | 09:37 AM
I shouldn't say I clutched the 325. I just changed the primary spring. Get with rick ritter cycle and he'll set you up. I was ready to do a full clutch kit and he recommended just a primary spring to start, which did the trick for $28. Didn't even have to remove the primary to change it. Very easy! Also Aaen performance sells slip on pipe's for your quad. They do make a difference!
Old Aug 25, 2010 | 10:42 AM
Big-O's Avatar
I agree with everyone on doing the clutch. It made a world of difference on my 01 Magnum. You may also want to check the buttons on the primary and put a new belt on to. As I said I did those three things and it was like a complete different ATV but keep in mind it this will not help with speed, just the power to the ground. Here is a link to a you tube sight that walks you through installing a clutch kit. This is not a Magnum but they are all basically the same. This is part one of four and you can do a search to get the other three parts.
YouTube - Polaris Sportsman EPI Clutch Kit Install - Part 1 of 4
Old Aug 25, 2010 | 09:07 PM
NCPolaris's Avatar
Thanks for all the help! Really appreciated!
Old Aug 25, 2010 | 09:17 PM
TLC's Avatar
TLC
The thing I don,t get is the ATV should go up a tree at just above idle while in low range even with stock clutching.
