03 Sportsman 90 brake lever
Old Sep 9, 2010 | 09:36 PM
dwabbit's Avatar
Default 03 Sportsman 90 brake lever
Hello
My son's Sportsman 90 is designed to start only if the left brake lever is applied. However,lately if you apply more than moderate pressure while trying to start it , the motor just cranks and doesn't run.When it is running, the same amount of pressure causes the motor to shut off. What might be causing this and how do I fix it?
Thanks for your help.
Old Sep 10, 2010 | 05:18 AM
Replace the starter interlock switch on the brake assembly,sounds like the little plastic plunger is damaged. Don't tie these switch leads together as the brake light will constantly stay on. Plunger switch just plugs in the housing. OPT
Old Sep 10, 2010 | 10:59 AM
dwabbit's Avatar
Thanks OPT! I'll pick one up this weekend.
greg74
Sep 10, 2019 03:03 PM
mtdewmn
Jan 19, 2017 12:13 PM
DeFox500
Jul 26, 2015 06:32 PM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
