How to reinstall cylinder on 400
Old Sep 11, 2010 | 08:18 PM
dingo2010's Avatar
Default How to reinstall cylinder on 400
I am putting the cylinder back on my 400. Does anyone know if I need any gasket sealer or anything on the base gasket when I put it in?
Old Sep 11, 2010 | 08:26 PM
Not necessary as from the factory gaskets just have a small bead of sealant around base gasket already applied. If using after market base gasket a small amount of 1104,1194,or Yamabond sealant can give a little piece of mind! Nothing worse than to have one leak and have to tear back down. OPT
Old Sep 11, 2010 | 11:00 PM
dingo2010's Avatar
It is an aftermarket gasket. I will have to look for the sealers you mentioned.
What about for the head gasket and the carb boot? Anything there?
Old Sep 12, 2010 | 05:06 PM
No sealant on head gasket, intake boot has molded rubber seal,BUT a little swipe of sealant around the the edges of the boot won't hurt anything if you have doubts. OPT
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
