Pin Hole in CV boot / Quick fix?
Old Oct 21, 2010 | 01:53 PM
09 popo HO's Avatar
Default Pin Hole in CV boot / Quick fix?
While trying to pull the right rear Axle to fix an outer boot I noticed I have a pin hole on the inner boot.
I could hear air pushing out when I plunged the joint in while trying to wrestle the axle.
Want to do a ride this weekend before the snow arrives. Is there any quick fixes that might get me through a couple weekends.
Once the snow comes I'll repack and replace the boot. Just trying to buy time.
Maybe a glue/sealant of some type. It's a small hole. No tear.
Old Oct 21, 2010 | 02:56 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Replace the boot. You do not know what has worked its way into the joint. It takes very little dirt to destroy the joint.
Old Oct 21, 2010 | 03:03 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it really isn't worth loosing a $200+ cv joint as you might have got water/dirt in it already. imo
Old Oct 21, 2010 | 03:05 PM
09 popo HO's Avatar
That is true.
There was no sign of any grease coming out of the pin hole until I was plunging it. I have it in my head that the hole is small enough that it acted like a baby bottle. wont leak until pressure is applied and thats when the grease came out.
And with my scranny 160lb body with HD springs I assume that joing aint plunging much.
I know this is all wishful thinking and I should at least take to boot off and have a peek at it and replace as soon as I can.
Another reason for my hessitation is that Polaris wants 58 dollars for one boot kit. That hurts since I may need two.
Old Oct 21, 2010 | 03:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Originally Posted by 09 popo HO
That is true.
well take it for what it's worth. i tried that very same thinking w/ the same size pin hole and you guessed it, i ruined my cv joint. so i learned an expensive lesson. if you do go out, make sure as too not get any water/mud any where near it.
Old Oct 21, 2010 | 03:25 PM
Rich720's Avatar
I would double check the boot price, I just paid $29 for one.
Rich
Old Oct 21, 2010 | 03:39 PM
09 popo HO's Avatar
Checked it twice. Even made an oouch noise when he said the price.
If I need 2 boot kits thats gonna be 116 plus tax so over $130. It hurts.
Old Oct 21, 2010 | 07:00 PM
weedy's Avatar
CheapCycle parts.com will be half that. Polaris brand boots are the best and the easiest to install.
Do not delay, replace the boot.
Old Oct 22, 2010 | 08:29 PM
Overdrive's Avatar
Retail on the boots are only $29 or $30. Your dealer is screwing you big time.
Old Oct 22, 2010 | 08:30 PM
Overdrive's Avatar
Also you can buy an entire aftermarket axle boots and all for about $150
