hilliard clutch problem
Old Dec 1, 2010 | 11:44 PM
kcaves's Avatar
easiest way to tell if ur getting power to the hub when u get ur armature plate put on. put ur machine in gear and see if u can pull ur armature plate off the coil, if u can than ur coil is most likely bad
Old Dec 2, 2010 | 09:59 AM
MECHANIKE's Avatar
hey saw a couple armiture plates on e-bay the other day,,,,,,,,,,,,,,trailer park boys rule!!!!
Old Dec 2, 2010 | 05:11 PM
jerdel6918's Avatar
well I put a new armature plate it cuz it was the cheapest fix and it works better and better ever time I drive it... can someone explain why its doing that... I went through some snow and she got stuck cuz it wasn't working right while I was trying to get it out it started working better and better... would the fluid make it do that?
Old Dec 2, 2010 | 06:53 PM
randyneff6971's Avatar
Can`t explain that, maybe there could have been some crud in the hillard and with the new armature plate actually holding to the magnet and engaging the hillard the crud is working its way out. If thats the case I`d almost be tempted to use the awd on and off a bunch of times and change out the fluid (flush out the system).
Old Dec 2, 2010 | 09:15 PM
  #15
jerdel6918's Avatar
Ya I'm starting to think that now... I just put my baby to bed and I have to put into awd do get in the shed but she couldn't do it cuz that damn clutch... I had to drive around for a bit to get it to go... or maybe the megnet is on its way out... I did check it and the plate stuck real good... I don't know anymore
Old Dec 2, 2010 | 10:24 PM
  #16
you may need to adjust it the Magnetic coil. I don`t have the spec`s at the moment. On 1 of the posts here there is a link about the front hub it explains how to do it. Now im thinking that the coils pull isn`t great enough and will engage when the fluid has warmed up. All thats required is adjustment, also there is a post somewhere on the net that explains how to check the resistance on the coil. I`d find it for you but its late now and I need to hit the sack. Its all easy to do you just need to understand how the front end works, its seems hard at first but once you get it you will wonder why it was so hard.
Old Dec 3, 2010 | 08:12 AM
  #17
jerdel6918's Avatar
I checked everything over even the gap... the only thing that I didn't check was the coil... I will check that today. How hard is it to take the old one out?
Old Dec 3, 2010 | 09:44 PM
  #18
its easy, just remove the hub and use a punch from the back side to remove the sleeve that covers the Magnetic coil, once thats off the coil is held in with silicone.
Before you do that, take the wheel off start the quad and hit the awd switch than take a screwdriver and lightly touch the strut housing as close to where you think the Magnetic coil is then gently move the screwdriver away. It should try to stick to the housing (Magnetic pull)if its working it will only be a light pull so don`t expect the screwdriver to stick there. Or you can take the hub completely off and try the same as stated above. If you suspect its working as it should and you have a new armature plate my next guess is its outside of the specified tolerances you will need feeler gages and a straight edge to check and set the sleeve.
There is a post on the front hubs explaining everything you need to do on a front hub.
Old Dec 4, 2010 | 09:26 AM
  #19
Jerdel6918. heres a link you should look at allot of excellent info and if you haven`t seen it yet you might want to save the address for future reference.
ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
skinnyr6
Aug 25, 2023 02:18 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
