Predator new piston new fuel?
Old Dec 8, 2010 | 07:09 PM
Predasaurous's Avatar
Question Predator new piston new fuel?
hello i have 07 polaris predator 500 i have a 560cc j.e bbk , but cant find any information on what type of jetting i need and what kind of fuel do i have to run thanks .
560cc
its got a aftermarket complete exhaust (dmc)
+ 1 size intake valves
Old Dec 8, 2010 | 08:49 PM
Doctorturbo's Avatar
GOT BOOST!
What's the static compression ratio of the piston?
Old Dec 8, 2010 | 09:14 PM
opps forgot to add that part
560cc 105mm +5.8mm 12.5:1
Old Dec 8, 2010 | 10:35 PM
sand addict's Avatar
what filter,do you have an open air box, or no air box,what carb, these are very important questions when jetting.12.5:1 is border line pump/race gas,what fuel are u using?are u using an open core muffler or a quit core?also what cam shaft?
Old Dec 8, 2010 | 11:11 PM
stock cam shaft and i have a k&n filter with airbox , with stock carb (jettin was done for my pipe) and my pipe is open core muffler .
also have a upgraded cdi box if that makes any difference and i always ran premium gas before
Old Dec 8, 2010 | 11:35 PM
on my notes for my dyno i have a couple of predators ive done,now i have an air/ fuel system for proper fuel raio's.now elevation changes final jetting,so it may vary a little,but this will help.main jet, 165 1 shim under needle and stock pilot at 2.5 turns out on mixture screw.this is for stock needle and with lid on.if its to rich u can take a uni bit and drill holes in your lid 1 at a time
Old Dec 8, 2010 | 11:39 PM
what state do u live in?for every 1500 foot above sea level u drop 1 jet size,all my testing is done at sea level
Old Dec 8, 2010 | 11:44 PM
i live in b.c. canada most of my riding is on wet mountians
Old Dec 9, 2010 | 12:17 AM
try those settings and let me know
Old Dec 9, 2010 | 10:32 AM
GOT BOOST!
12.5 to 1 is race gas territory IMHO. You will be mixing at the very least.
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
