Secondary Clutch Spring
Changing it to what?
Going with a softer spring will allow the belt to sink further into the clutch easier, which means it will be upshifting sooner. This would probably give you a little better feul milage.
More likely you would move to a heavier spring, which would keep you in low "gear" longer, would raise your rpm at most given speeds, and makes the bike a little peppier.
I think I would change the helix rather than the driven spring, though changing your primary spring might be a good idea.
Steeldon
Sep 9, 2015 09:38 AM
