01 xpedition electrical craziness...
Old Dec 10, 2010 | 08:05 PM
Sleddingfarmer's Avatar
Default 01 xpedition electrical craziness...
I have a 01 Xpedition 425.. Never had any issues with it pretty much because of its limited use... It had sat for a good 1-1.5yr before I had it get all tuned up and running this past spring upon moving to my new house. Its only set for 2-3wks tops since then...
I got a snowplow to put in Sept and finally it was time to put it use... Used it monday &tues and was great... It had been starting at all the past couple months using the ES so I put my little charger on it(trickle 2amp) overnight wed. Go to use it yesterday and there was nothing off the starter. When i lift the "starter" button something just spun/buzzed(starter solenoid perhaps) It'd go for several seconds even i just bummed the starter... Hmm....
So decide to just get plowing, pull out of the garage, noticing that the green N is still on, go to put it in reverse and nothing.... No shift, no light nothing.. Then I noticed speedometer was dead, no display or background light.
Ok, ill try to plow only going fwd(doesnt really work fyi) In this short bit I got the reverse to work 1 or 2 that was it , no rev since. It then started to have trouble pushing and I noticed the AWD was kicking in and out. It went out in a snow bank, so i just sat there for min or 2 til it kicked back on and just went and parked it..
I sat with it a few times waiting and when the AWD light would come back on it coincided w/a solenoid click sound up front somewhere. At the end I no longer had the Green N light on nor come even when in N. With all this in mind, my headlights and the winch continued to work perfectly fine. And if I would shut the lights off, while the green N light still was on it got much brighter(obvisouly with less draw)
Back in the garage, i attempted to put my charger back on to see what would happen. Upon connecting the cables w/in 2-4secs something w/in the charger would pop internally and I'd see a light flash..Circuit breaker maybe, idk? The charging light wasnt on either. So i put it over on my mower and worked fine... charger is just a little 2/10/55 amp from carquest, has no amp meter or whatever on it tho.. i dont know if when i put this on overnight, did it pop all night/day long and somehow fry the system?? Although nothing was making noise when walked into the garage, because I wouldve noticed it...
I know this is long and perhaps not making total sense, but where in the world do i begin?? Im not really eletrically savy, I can do it with a good guide or steps,usually...
Reading through the Poo service manual going through the electronic section, it seems that if the speedometer takes a dump it could control a lot of similar problems ... But I dont have any of the tools it talks about using to test or any clue how to work them...
Any help would be appreciated...I got a few piles that I pushed up but not off the driveway when i tried to go that now are solid ice...Id like to move them soon
Old Dec 11, 2010 | 03:18 AM
4getful2's Avatar
I'd try taking the battery out and charging that way, then clean all your battery connections, especially the grounds and i believe there is more than one ground cable(frame to motor). look at the connections at ignition switch
Polaris must have changed things from '01 to '02, on the '02 i used to have the starter worked off the key switch(like a car) and not the handlebar switch. Y ou can manually put it into reverse by lifting on the lever by the reverse actuator, when in nuetral ,lift on lever and push down foot lever
Old Dec 11, 2010 | 12:25 PM
I pulled the battery out to try and it kept popping the charger off.. Went and found a load tester and showed nothing..Went and found someone w/a multimeter and it was only around 9.5-10v and while trying to power a light it would drop down to 7ish.. Attempt to charge it off a larger charger w/gauges and it was popping that one off as well, so 65 bucks later I have a new battery...
The guy lent me his tester so after installing the new battery i checked voltage to make sure nothing else might be wrong and it gave a consistent 14.2-14.3 sitting and only dropped down to mid 13 when running the winch...
I have reverse again and the reverse light on the speedo. But i DONT have the green N light, no power to anything else w/the speedo and no AWD still...
Update.. Ran the tests from the serivce book and it seems to point to a bad speedo... I looked one up on Partsland and its 320bucks!!! Looked w/no luck on ebay... Any reputable sites for used parts??
Old Dec 12, 2010 | 09:56 AM
4getful2's Avatar
and you did check the little bulbs inside. it's just that since you had battery issues, makes me wonder that it didn't overcharge and pop the bulbs . polaris's are kinda known for that.
babbits online
cheap cycle parts
Old Dec 14, 2010 | 06:26 AM
babbits online
cheap cycle parts
I didnt check the bulbs. My reverse bulb lights back up w/new battery but not the N light.. That one i think might require a new bulb, that's no biggie... For now I'm just going to try and get the speedo off, secure all cover the wires and just use a jumper to get my awd working.. Have to do something, have about 10-12" of snow in the driveway attm, with just as much again expected by tomorrow...
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
