Grease fittings on HO??
Old Mar 8, 2001 | 08:00 PM
packrat's Avatar
How many are there? I count 24 on my HO.Am I missing any?
Old Mar 9, 2001 | 01:24 PM
Deej's Avatar
Here is a copy of an old post I made. This covers the zerks on the old ones as well as the new HO. It is a bit lengthy but the info is all there.
This list agrees with the zerks illustrated in the Polaris Sportsman Service Manual.
This is the list for my '98. The differences with the new ones are discussed below.
2 - L&R front lower ball joints
2 - L&R outer tie rod ends (not on newer units)
2 - L&R inner part of front control arms
2 - L&R front inner U joints
1 - lower steering post (not on newer SP)
1 - upper steering post
1 - u joint at prop shaft leading to front
1 - u joint midway on prop shaft (under recoil)
1 - yoke joint in prop shaft (also under recoil)
1 - foot brake pedal pivot point
6 - L&R rear lower control arms (2 outer, 1 inner)
6 - L&R rear upper control arms (1 outer, 2 inner)
2 - L&R ends of rear anti-roll bar
2 - L&R rear inner u joints ('98 and older only)
2 - L&R rear outer u joints ('98 and older only)
This totals 32 zerks on my '98! The newer '99s and 00's should have 6 less, totalling 26. The newer units do not have greasable outer tie rod ends (less 2 zerks), and they have dual CV joints instead of u joints on the rear drive shafts (less 4 zerks).
The newest (2001) Sportsman will be missing the one on the lower steering post.
So the way I see it there are 25 on the 2001s.
Other Notes:
I slip grease into my ungreasable inner tie rod ends using a grease needle.
Polaris warns that 3 pumps maximum should be used in the prop shaft yoke.
Polaris recomments that the u joints are filled until fresh grease is expelled from all 4 sections of each joint. This way all water and dirt should be expelled.
Greasing is relatively quick once you figure out how to access all of the zerks.
Hope this helps,
DJ
Old Mar 9, 2001 | 02:54 PM
500DUSE's Avatar
There are 24 on my 01
Old Mar 9, 2001 | 04:52 PM
packrat's Avatar
Thank you gentlemen for your reply.
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
