Sportsman 800 2006
Old Feb 4, 2011 | 05:38 PM
schmidthead74's Avatar
Default Sportsman 800 2006
Need some help- the 4x4 stopped work. The light shows up on the pod but will not kick the front wheels into action. Where should I start? I read the asm could be bad- but I don't know what that is. Also they say a plastic pcs on the front could break? Can anyone help?
Old Feb 4, 2011 | 07:14 PM
awsume800efi's Avatar
more than likely the plastic roller cage in the front end
Old Feb 4, 2011 | 08:34 PM
I tore down the front diff tonight- the cage is in one pc with a couple cracks and the roller are full of crap. The cage is not broke into pcs though, I plan to order all new but is there anything else it could be since it's not broke into pcs. Or could the cracks and rolls be causing it.
Old Feb 4, 2011 | 09:24 PM
Kerbbirds's Avatar
John deer parts are much cheaper , money wise,
Roller kit# MIA10666
Cage kit#MIA10667
Seal KIT #MIA10654, take your old cage an rollers with you to make sure their right if its cracked and dirty thats probably the problem
Old Feb 5, 2011 | 05:00 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if the roller cage is cracked you have found your issue. make sure to clean the fornt end out god and put the proper polaris front end oil only back in or maybe what john deere sells for their hillard front ends. imo
Jmuddin284
Jan 19, 2026 07:16 AM
velcro7279
Aug 24, 2015 01:15 PM
donintennessee
Aug 19, 2015 02:22 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Gtsordo
Jul 13, 2015 10:38 PM
