Wierd starting problem on 04 330 Mag
Old 02-13-2011 | 08:17 PM
fxstrider03's Avatar
Default Wierd starting problem on 04 330 Mag
I have an 04 330 mag that starts on the first pull but won't start with the starter. Has new stator, carb cleaned, 180psi compression and runs gerat except it won't start with the starter. I took the starter apart and everything looked good. Cleaned commutator and brushes were like new. Starter spins the motor over fine. It's getting gas and a shot of starting fluid doesn't change anything. Pull the plug and has great spark since I installed the new stator. Not much hair left to pull out so any help is appreciated
Yamaha_
Utility ATVs
12-16-2022 07:49 PM
generalpops
06-05-2015 08:23 PM
garyt1975
06-05-2015 08:53 AM
generalpops
06-03-2015 08:25 PM
1000gade
05-27-2015 12:37 PM
Quick Reply: Wierd starting problem on 04 330 Mag
