Do 2000 Sportsmans have fuses?
I have a 2000 Sportsman 500 that will not start. First I thought the starter was no good, I can start it with the pull cord but not with the key. However when the key is on none of the lights work unless the machine has been started with pullcord. Is there perhaps a fuse buried somewhere inside this thing?
There are no fuses on a 2000 but there should be an inline breaker which resets itself. If it goes bad it could cause you some issues but it sounds more like a bad battery. Have you tested the battery? Check your battery first, then starter solenoid, then the starter itself.
I did replace the battery and seems like right after I changed it the starter stopped working, that's why I jumped to the conclusion of a dead fuse. Thanks for the input.
