1999 Xplorer 400 Piston 38B
Old Mar 29, 2011 | 12:44 PM
trbojet1's Avatar
Default 1999 Xplorer 400 Piston 38B
I'm rebuilding a 99 xplorer 400. I pulled the top end. Found a little scoring on the piston. I would like to have it oversized. On the top of piston it is marked 38B. I know that the stock is a 38A piston. What does 38"B" mean? Thanks
Old Mar 29, 2011 | 01:06 PM
94harley's Avatar
According to the manual the 38B is the standard piston and fits the EC38PLE-06, 07, 08, 09 these numbers are not 2006, 2007, 2008, 2009
The 38A fits the EC38PLE-04, 05
I wouldn't use a Polaris piston anyway. Go with a wiseco piston. They will last a lot longer and don't have the famous catastrophic piston skirt breakage like the Polaris pistons.
Old Mar 29, 2011 | 01:41 PM
trbojet1's Avatar
Thanks, do you have experience with the 99 xplorers? I'm try to figure where the water is coming from on mine. Milky white oil coming from the counterbalancer breather/vent line. I'm hoping it's not coming from the water pump seal. I have the top end off now and am replacing the head and lower gaskets.
Old Mar 29, 2011 | 02:11 PM
94harley's Avatar
Probably the water pump seal like you said.
Old Mar 29, 2011 | 06:16 PM
Jmuddin284's Avatar
X2
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
rockinkgin
Sep 25, 2015 01:52 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
