Dipstick tube leaking
Old Apr 6, 2011 | 02:24 PM
thewasp's Avatar
Default Dipstick tube leaking
2004 sportsman 600. Leaking oil from dipstick tube. Replaced the oring with oe part and an aftermarket one, even tried to use silicone. Still no luck. Any one had this problem? If so what's the fix?!?!?
Old Apr 6, 2011 | 06:21 PM
Kerbbirds's Avatar
dipstick tube is cracked my 700 did it, order a complkete dipstick tube and replace it, the vibration must get to them
Old Apr 6, 2011 | 07:14 PM
thewasp's Avatar
I will check that. Where do they crack? At the oring?
Old Apr 6, 2011 | 07:59 PM
Kerbbirds's Avatar
cant remember but if you remove it and clean it up, then plug one end and blow in it or put a little air to it youll find it, seems like it was up around the mounting tab
Old Apr 8, 2011 | 08:56 AM
thewasp's Avatar
Well the tube isn't cracked. But where the hold down clamp goes it shows some signs of wear as well as the clamp itself. So I'm gonna order a new tube and clamp and cross my fingers!!
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
