99 sportsman hillard hub question
Old Apr 10, 2011 | 07:53 PM
jflib74's Avatar
Default 99 sportsman hillard hub question
Can any one tell me on the front hub where the coil slides on theres an inner and outer pole where the coil sits between looks like the hub was over tightened at one point the inner is crushed in. is the inner part of the strut housing? the inner and outer are suposed to be flush with a straight edge and there not even close!
Old Apr 10, 2011 | 07:55 PM
jflib74's Avatar
the armature plate actually has a bowl shape to it where the inner was crushed in. and its suposed to be flat to !
Old Apr 10, 2011 | 08:27 PM
If the inner face is ground down,this is part of the strut housing. The top sleeve is a press fit that goes over the coil. Both should be even with each other (give or take .001 difference) and fairly smooth,not rough. You can try to smooth out,but if its like the ones I've encountered it will affect awd and strut may have to be replaced? If you could post a picture sure would help! OPT
Old Apr 10, 2011 | 09:14 PM
jflib74's Avatar
the funny part is this side works fine! i took it apart to see what was different because the drivers side doesn't unlock it stays locked all the time.
Attached Thumbnails 99 sportsman hillard hub question-photo.jpg   99 sportsman hillard hub question-photo-2-.jpg
Old Apr 10, 2011 | 09:41 PM
From what I could tell it looks like the inner is not ground that bad, but the outer sleeve is past clearance? If the other side is engaged all the time,its usually the armature plate being magnetized, I would at least replace the plates. Does outer sleeve fit tight against strut and enclose coil assy good? Outer sleeve could have moved if didn't have enough silicone when installed,BUT looks flush with strut. The plate looks warped and deformed though,could have been too tight.Be sure to torque to 12 foot pounds only on hub nut. I guess the old saying if it ain't broke.................. OPT
Old Apr 10, 2011 | 09:55 PM
jflib74's Avatar
That black plate is the armature plate correct? If I put a new one on it won't touch the inner it'll be off like a 16th of an inch. And if that is the armature plate the other one doesn't seem magnetized any other ideas
Old Apr 10, 2011 | 10:00 PM
jflib74's Avatar
The speedo needle doesn't work buy hours, miles light up but speedo issues usually makes the 4 x 4 not work at all correct? Sorry for all the questions!
Old Apr 10, 2011 | 10:20 PM
1/16 of an inch isn't that far off,just dont over tighten the hub nut and see if operates correctly with all wheels off the ground.I still would replace both plates as the other will eventually need replacing,not that expensive! Make sure you use Polaris Demand Drive plus hub fluid. Trying to help you keep the strut if possible.
Old Apr 10, 2011 | 10:21 PM
Usually the wheel speed sensor fails on right front caliper,won't show speed or mileage
Old Apr 29, 2011 | 11:30 AM
jflib74's Avatar
All back together and that side still doesnt work think theres to much space between innerand outer cant have more then .001 correct? Driverzside works awesome now! Getting closer!
