Front Differential
Old Apr 14, 2011 | 11:19 AM
maverick11's Avatar
There are two of the size you are talking about. Both are labeled #6 in that diagram. There is a third that is on the input labeled #17. A kit for this comes with all three of these bearings and seals for each. I am only replacing the #6 bearings cause they are the only ones I have loose.
Old Apr 14, 2011 | 11:33 AM
TLC's Avatar
TLC
This will make it easier http://www.cyclepartswarehouse.com/f...006&fveh=39673
Separate housing #20 from cover plate #2 bring housing to any shop and they will take the bearing out cheap. No special tools to seat a bearing back in but why not let them do it as well.
Old Apr 14, 2011 | 11:38 AM
Spdecat's Avatar
You are correct there are three I missed the other two . It don't look to be that bad of job have fun .
Old Apr 14, 2011 | 11:40 AM
maverick11's Avatar
The more I look at the diagram, the more intimidated I get by the project. A lot of rings and parts to get back together correctly lol... and anything for sure on if I will need the pullers or not?
Old Apr 14, 2011 | 11:47 AM
  #15
TLC's Avatar
TLC
I know people who changed the Plastic roller cage #10 who said it was not that bad of a job. Doing the bearing is only one more small step.
These guys sell the bearing for $33 rather then $49.Dirt Cheap Yamaha, Honda, & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Apr 14, 2011 | 11:54 AM
  #16
maverick11's Avatar
while I have it apart, I might just see if there is anything else wrong. I'm hoping once I'm in there it will just seem easy.
Old Apr 14, 2011 | 05:13 PM
  #17
Kerbbirds's Avatar
if the plastic cage is cracked you can get the parts from John Deer much cheaper than Polaris, onc e you get the bearings off I"ll bet you can get them matched up at your local parts house, let us know what you findn and I can give you the John Deer #'s if you need them
Old Apr 15, 2011 | 07:09 AM
  #18
maverick11's Avatar
Thanks, I'll let you know once I'm in there.
Old Apr 15, 2011 | 11:33 AM
  #19
maverick11's Avatar
Any one know how much Ill be looking at for the cage if it is messed up through john deere?
Old Apr 15, 2011 | 11:58 AM
  #20
TLC's Avatar
TLC
Here is one for $199 made for a Polaris Ranger RZR but I think they use the same roller cage as the ATVs you would have to find out. Polaris Ranger RZR - Sprague Carrier/Front Roller Cage - Polaris RZR - Performance Parts Accessories
Here is a link you should read also http://forum.highlifter.com/john-dee...-m1942879.aspx
