Front Differential
Old Apr 15, 2011 | 12:12 PM
  #21
maverick11's Avatar
Then I hope mine is fine if they cost that much. I thought they were plastic though?
Old Apr 15, 2011 | 12:25 PM
  #22
TLC's Avatar
TLC
The metal Roller cage are aftermarket, there more money but are much stronger. Not sure when Polaris will just put metal ones in on there own and discontinue the weak plastic ones.
Polaris does not care because the plastic one shatter after the warranty runs out.
Old Apr 15, 2011 | 12:38 PM
  #23
maverick11's Avatar
I understand the initial idea of the plastic because when it goes then nothing else will be damaged... but they really are trying to just make a buck. Typical. I wonder how polaris feels about the fact that john deere parts fit... and for cheaper.
Just curious sake... why do john deere parts fit?
Old Apr 15, 2011 | 01:17 PM
  #24
TLC's Avatar
TLC
The older AWD setup had a metal roller cage in each hub without issue, just have to replace a seal once in a while.
Old Apr 15, 2011 | 01:23 PM
  #25
maverick11's Avatar
I would assume that my cage is fine since my 4x4 is working good other then all the play in the drive shafts.
Old Apr 15, 2011 | 01:46 PM
  #26
TLC's Avatar
TLC
If the AWD is working then the cage is good.
Old Apr 15, 2011 | 05:42 PM
  #27
Spdecat's Avatar
I'm watching the play in my front drive shafts also was told to fix that if ever needed I would need to install two new output hub assembles in the front hilliard . Hopefully I will never have to .
Old Apr 15, 2011 | 08:05 PM
  #28
Kerbbirds's Avatar
go tear it apart and quit yackin about it on the forum, the only way you will ever know whats wrong, sorry if I"m too blunt
Old Apr 18, 2011 | 08:47 AM
  #29
maverick11's Avatar
I would be done by now but still waiting on replacement parts.
Old Apr 20, 2011 | 09:35 PM
  #30
maverick11's Avatar
Ok so got the differential out but how do I get the drive shafts out of it
