Front Differential
Old Apr 21, 2011 | 07:09 AM
  #31
Kerbbirds's Avatar
you shoulda pulled both front axles out before you unbolted diff, do you have a service manual? if not try to find one
Old Apr 21, 2011 | 07:48 AM
  #32
maverick11's Avatar
I have a repair manual but it was not clear on how to remove the drive shafts from the differential. It claims there is an internal snap ring but I wouldn't know how to get to them without taking the diff. apart anyway... I'm confused here...
Old Apr 21, 2011 | 07:49 AM
  #33
TLC's Avatar
TLC
They just hank out, it would of be better to hank/jerk them out before you took the diff out.
The shaft is held in by a compression clip (Snap Ring).
Here,s a Video of a guy pulling one out. http://www.youtube.com/watch?v=o8iZp...eature=related
Its a Can AM but there all held in the same way.
Here is how you do it if its rusted in place. http://www.youtube.com/watch?v=TjXw8...feature=fvwrel
When you put it back it use ati seize lube on the spline so it comes out easier next time, if you need to do a cv boot change down the road.
Old Apr 21, 2011 | 08:09 AM
  #34
Kerbbirds's Avatar
there not all that easy, Ive had to use a slide hammer to pull them
Old Apr 21, 2011 | 08:14 AM
  #35
maverick11's Avatar
OK well this gets me going in the right direction. Will I have to replace the clips once I put it all back together?
Old Apr 21, 2011 | 08:17 AM
  #36
TLC's Avatar
TLC
I use the same clip, when I do a CV boot change. If it looks good you can reuse it.
Old Apr 21, 2011 | 08:52 AM
  #37
Spdecat's Avatar
Look in your manual it will say don't reuse the clip replace with new .
Old Apr 21, 2011 | 08:56 AM
  #38
TLC's Avatar
TLC
The manual also says don,t have a beer on the trail. LOL
Old Apr 21, 2011 | 09:19 AM
  #39
maverick11's Avatar
I will inspect them and see if they are worth reusing. If I can get new ones before I ride I will.
Old Apr 27, 2011 | 05:19 PM
  #40
Spdecat's Avatar
How'd you make out all fixed ?
