trans problems w/01 Scrambler
The problem I'm having with my 01 Scrambler 500, is it doesnt want to stay in H . It stays in R just fine. I have searched and found out that the problem is most likely the Engagement dog and or the shift fork that needs replaced. I have adj.,d the shift rod and that didnt work so I'm going to ceck the fluid today but I have a feeling thats not the problem.
So who has done this and how hard is it ? Is there any specail tools that are needed ?
Thanks
I just bought the quad about 2 wks ago and everything wored great until i was out riding the other day and it wouldnt stay in H. It didnt give me any signs ahead of time. I,m just glad I made it home that day.
and It will go into gear but seems to slide out when you start to give it gas.
Thanks
Ok I finaly got the primary clutch puller and working on getting the trans out. Now the big question is HOW do you get it out ? Everything is all unbolted and I cant seem to get it out. The only thing still connected is the front driveshaft and that looks like it will just slide out. Does the swingarm need to come off ? If anyone has an easier way I'd be willing to pm you my # so I can get this fixed.
Thanks
Thanks
Thanks
Thanks
Thanks OPT its out now
Now I tore it apart and cant't see any wear on the gears or the dog so I'm going to take it to the dealer and see if they can tell me it has any wear on them. The fork only had slite wear on it not even enough to catch when your run your finger nail across it.
So i think I'm going to head p to my local dealer and see ifthey can tell me whats worn.
If you still have apart check the silent chain,if has a lot of slack could be the problem,plus the gear teeth itself on the small forward gear and also if the dogs on the sliding gear(hi/rev) is real shiny and worn. OPT
The dogs looked fine not alot of wear. The chain does have some slop in it , side to side maybe. If you hold it horizontal it has up and down play and the teeth didnt look to bad to me.
So the chain can cause the trans to slide out of forward when you give it gas ?
