2009 850xp oil in airbox fix out yet?
Good day to everyone. I am sorry I have missed all the threads on this subject. I'm asking agagin because I have this issue, and was wondering if anyone has a fix for it yet? I have always let the machine warm up before use here in the michigan winters. With warm weather I am still getting oil deposits in air filter box. The oil level is now just barely touching above the minimum mark on the dipstick. (I say that because the dealer said I may of had to much oil in the machine) I have never rode wheelies with it. I have about 220 miles on the machine. Polaris obviosly will not stand behind a major problem like this which gets me issed off! Over $7,000 I should not be having this problem. Thans to anyone that can point me in the right direction. Marc
Well after some reseaerch a gentelman named supercoe (I think ) has sugested to remove pcv valve, remove felt filter, lube rubber o-ring gaskets, then work the valve back and forth with a twisting motion while reseating pcv valve, then insert bolts and tighten. I will monitor this to see if it works. I just dont like the thought that all my oil is going into the airbox. Anyone else with any other info for this prblem? any and all help is appreciated. Thanks
braap123
09-07-2015 12:58 PM
braap123
09-07-2015 10:57 AM
