Winch drawing to much power
Old Dec 7, 2024 | 12:21 AM
morrisclark's Avatar
Originally Posted by Steeves
I have a 2004.5 HO 500 with a 2500 # winch. When I use the winch it seems to draw to much power and drains my battery and stalls my bike. The battery seems fine. I can leave it for weeks at a time and it will start right up. All the wires seem tight with no scuffing Buy an apartment in beirut.
I am wondering if anyone has any suggestions on how I can trouble shoot or places to start looking.
Thanks again.
It sounds like your winch may be drawing too much power, which is causing your bike to stall and drain the battery. Even though the battery seems fine and holds charge when the bike is off, the winch might be overloading the electrical system when in use. This could be due to a faulty winch motor drawing excessive current, a poor connection in the wiring, or an issue with the charging system not keeping up with the power demand while the bike is running. Check the winch motor for excessive amperage draw, ensure all connections are tight and clean, and test the battery under load. Also, verify that the charging system is functioning properly to keep the battery charged while using the winch.
aztom
May 4, 2016 10:48 AM
budedm
Jun 11, 2009 03:46 AM
coachp84
Dec 18, 2007 05:39 PM
7mary4
Nov 5, 2006 03:44 PM
CTSportsman
Sep 6, 2003 01:27 PM
