'95 trail boss 250 tranny trouble
Old 07-04-2011 | 07:37 PM
missy woge's Avatar
Default '95 trail boss 250 tranny trouble
Reverse works great, but in forward, the transmission is slipping, (almost makes you think the chain is slipping, but not that lucky)How bad is tearin the tranny apart to check the silent chain? Does anyone have any suggestions, or some insight to what it may be or what we are looking for? Thanks! Also, any info on adjustments, and where to put the tranny fluid in would be appreciated!
Old 07-04-2011 | 08:30 PM
If you haven't already checked the front sprocket for worn teeth and also for worn inner splines part #(3221044), I would check this first. The 95 2x4 transmission was a transitional year as parts depended on serial number of the transmission! The main tool necessary to pull the transmission is the front clutch puller as both clutches have to be removed,But I would invest in a manual (some posters may have a free source online) and you can look up the exploded view on the transmission on Pure Polaris Parts Catalog OR Cycle Parts Warehouse. If outer sprockets are ok,the most common reason for slipping was the internal chain which would stretch OR the forward engagement gear dog wear OR a combination of both! OPT
Old 07-04-2011 | 09:09 PM
Overdrive's Avatar
From what I have seen most of the time it is the chain. Once you replace the chain and anything else that it needs there is one quick and easy thing you can do that makes a HUGE difference in how long these parts last.
Fill the trans with Castrol Syntec 5w50.
Old 07-05-2011 | 08:58 PM
missy woge's Avatar
Default tranny re-build, '95 polaris 250 trail boss
thanks for your advice...any words of wisdom for us when we take it apart?Anything will be appreciated!
Old 07-05-2011 | 09:07 PM
Kerbbirds's Avatar
Its not hard to take it apart, the hatd part is gettin it out of the frame,
Old 07-06-2011 | 07:45 AM
missy woge's Avatar
Yeah, I absolutely hate takin all the plastic off.....every little thing that needs done takes twice as long!! Thanks!
Shainasmash
05-08-2017 07:38 PM
Old Deer Hunter
09-02-2015 02:39 AM
Anomers
08-16-2015 12:06 PM
Backwoods_badass
08-01-2015 11:25 PM
Gnuters
07-19-2015 11:03 AM
