Is my motor going???
I have a 99 sportsman 500, seems it's always been kinda noisey when at idle but latly it seems to almost nock, and idle super low, but when i give it a little gas the motor sounds great, and still has all the power it's always had, is this motor going or do i just need to idle it up, little worried, almost sounds like top end don't know.
A low idle knock isn't uncommon, but it also doesn't mean the motor is fine.
Are you noticing any type of metal in the oil when you change it?
do a compression check- you'll atleast have an idea how the top end is.
might need some rod bushings or a bottom end rebuild or a clutch. There's really over a hundred things that can cause what you're describing.
polaris atv's are normally noisey- but since you've been riding it for a while, you know the typical sounds...
Ok thanks guys for all the input, i changed the oil yesterday and it didn't seem abnormal, i'll put an ear to the belt cover today, it might be the clutch it didn't get to loud until I put 27's on it, also if it was the timing chain how would i check that?
